Worked on a mounting bracket for the transponder and radio.
Some AeroVee owners reported having problems cross threading the upper aft spark plugs due to interference of the spark plug socket with the intake manifold. I've found putting the plug in using a piece of plastic tubing to get it seated and then using a pressed steel type spark plug socket to tighten the plug works well.
